July 31, 2020 at 2:34 pm
prajput
Ansys EmployeeHello, what is the difference between internal and external flows?
Ashish Khemka
Ansys EmployeeInternal flows are defined by moving fluids surrounded by solid surfaces. For example water flowing inside a pipe.
External flows instead are unbounded flows that move over bodies. For example air moving over a car.
For detailed discussion on aspects of internal and external flows, check out the respective courses that are part of the Basics of Fluid Dynamics Learning Track on the Ansys Innovation Courses webpage.
https://courses.ansys.com/index.php/courses/learn-fluid-dynamics-basics/
- What is the difference between internal and external flows?
- How do you define specific gravity? What is its significance???
- Why is it much easier to roll a log than drag a wood cube with the same mass?
- The level of water inside the straw was higher than the level of water in the beaker
- What is the surface tension of a fluid?
- How to gain research experience?
- Whats the difference between sensible heat and latent heat?
- Cell Counting?
- Why does the total sum of forces acting on a system always have to be equal to zero?
- Why ice floats on water
2706
2142
1357
1144
462
