March 17, 2021 at 8:54 pm
prakhars962
SubscriberMarch 19, 2021 at 8:51 am1shan
Ansys EmployeeHello Array,nWith a rigid definition the solver does not generate a mesh for that particular body(nor can you calculate stress/deformation results for that body) but rather only calculates kinematic variables (like velocity, position) as well as forces and moments across connections scoped to the body. It is mostly used in in multibody dynamic simulations where the primary interest is in calculating kinematic variables like velocities, accelerations, positions of different components rather than the stress/ deformations in each. If you are interested in calculating stresses inside only one component of a big assembly you could define that component as flexible and the rest as rigid. This would direct the solver to mesh and compute results for just 1 component rather than the whole assembly. You could check out the transient analysis of digger arm tutorial https://courses.ansys.com/index.php/courses/time-domain-dynamic-problems/lessons/homework-quizzes-simulation-examples-time-domain-dynamic-problems-lesson-6/and the related course.nRegards,nIshan.nViewing 1 reply thread- You must be logged in to reply to this topic.
2726
2146
1357
1150
462
