September 27, 2018 at 9:53 am
Adisa
SubscriberHi, I have read this:
https://www.researchgate.net/post/What_is_the_difference_between_static_and_dynamic_impact_strength
And know, I am interested in how to calculate dynamic factor and get dynamic stress which will be the ultimate stress. The dynamic stress I need because I am doing shpere test in transient structural, So far I did not use dynamic stress for this type of the analysis. I am using the total strain as criteria break. how I need to use dynamic stress or maybe dynamic strain in this type of analysis, drop test.
October 5, 2018 at 1:11 pm
Ashish Khemka
Ansys EmployeeHi Adisa,
I did not see any guideline in our documentation for this.
Ashish Khemka
October 5, 2018 at 4:16 pm
SubscriberHi Adisa,
The title of your post asks a question. In the context of ANSYS, there is no such thing as dynamic impact strength.
The body of your post says you are doing a ball drop test in Transient Structural and you will compare the Total Strain with Elongation at Break to decide when failure has occurred. This is a good start. The question is what material properties are you using?
Some materials exhibit a significant sensitivity to strain rate. That means the material may have a low stiffness and a large Elongation at Break for low strain rates, and a high stiffness and a small Elongation at Break for high strain rates.
You can explicitly model strain rate in the Anand Viscoplasticity material model, which I added to a Nylon 6/6 material. I don't know how to use this material model, I just show it as an example of how strain rate can be included in the model.
2120
1347
1118
461
