January 12, 2022 at 7:50 pm
jcastel
SubscriberIn a UDF I am using: " loop(I, Ilist) { loop(p, I->p) { " to loop over all the injections in my simulation and then the each particle in each injection I would then like to get the position of each particle "p" using the macro TP_POS(tp)[i].
I appear to be getting a problem when i try to call the TP_POS(p)[i] because "p" is in the format of the "patricle_struct" but the macro is looking for "tp" in the "tracked_particle_struct" format.
February 15, 2022 at 6:28 pmSurya Deb
Ansys EmployeeHello,
Please use the "tp" definition as it will be able to access the position and other related variables for tracked particles.
For more details, please refer to the link below:
Regards SD
February 15, 2022 at 6:29 pmViewing 2 reply threads- You must be logged in to reply to this topic.
3744
2573
1821
1236
594
