August 28, 2023 at 9:21 am
Soufiane El kabil
SubscriberI try to simulate the some electromagnetic field by using the PML as BC on 2D system, because the sample is infinite on x axe and seminfinite on y -axe (finite on the positive one and infinite on the negative one), which confused me , because I don't understand, if I have to use PML on all sides or I have to use another BC to absorb all incident light
August 28, 2023 at 10:32 pm
Guilin Sun
Ansys EmployeePML is to truncate the object to be simulated;
For 2D, if x direction is infinite you should use periodic BCs (normal incidence) but Y axis uses PML. Please try.
- Error on Lumerical device
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Lumerical – error message when trying to open from Linux terminal
7626
4456
2955
1427
1322
