March 10, 2022 at 1:09 pm
uttam60
SubscriberHi all,
I am quite new to using ANSYS Mechanical 2020R2 for analysis and am currently studying its functioning in order to integrate it to HPC. I was trying to run some basic tests with sample models using the windows command prompt but I am facing certain issues.
I am using the command (something I obtained from Mechanical APDL Product Launcher):
"C:Program FilesANSYS Incv202ansysinwinx64MAPDL.exe" -p meba -smp -np 1 -lch -dir "directory" -j "jobname" -b -i "inputfile.inp" -o "outputfile.out"
The output files I receive are as shown in this image
March 11, 2022 at 1:01 pmAniket
Ansys EmployeeHave you tried opening bike_crank_3.rst which is the largest combined rst of all the files?
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/ans_dan/dan_startlaunch.html%23dan_startCL
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/ans_ope/Hlp_G_OPE3_4.html%23batchcommand
Please check the above links for more explanation, but removing SMP (i.e shared memory parallel switches the solver to distributed causing it fire it in DMP mode.
-Aniket
March 11, 2022 at 2:18 pmuttam60
SubscriberThanks for you reply and support Aniket
2630
2106
1335
1110
461
