May 17, 2022 at 2:53 pm
cnemecek05
SubscriberI am trying to predict the heat transfer coefficient to an avionics box with a known power dissipation (ie, watts). There is an impinging jet on the box providing cooling. The simulation domain consists of the fluid volume only. The avionics box is not modeled as a solid, but just as a void in the fluid volume. Is it appropriate to specify the heat generation rate of the box as the known power dissipation divided by the volume of the box?
May 17, 2022 at 3:17 pmRob
Forum ModeratorPossibly, the problem with that is working out how much heat would be lost to each surface. Ie is the box cooled more on one side than the other, and what does that do to the heat loss & temperature distribution?
May 18, 2022 at 3:12 pmcnemecek05
SubscriberFor the purpose of this problem, we would assume the power dissipation is evenly distributed across all surfaces of the box (ie, an area-weighted average for the dissipation) such that integrating the heat flux across all surfaces yields the known power dissipation. The box will be cooled more so on one side, but we'd still assume the power dissipation is an area-weighted average across all surfaces.
May 18, 2022 at 3:54 pmRob
Forum ModeratorIn which case I'd use a heat flux, ie W/m2 The heat generation is more for heated layers in systems, eg a thin heating element between a steel & insulation solid on a pipeline.
May 18, 2022 at 6:02 pmDrAmine
Ansys EmployeeEnergy source when soving temperature equation for the wall as a layer.
Viewing 4 reply threads- The topic ‘What is the “heat generation rate” for thermal wall boundary conditions?’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
