July 31, 2020 at 1:38 pm
KR
AdministratorHello Experts,
What is the impact of having a pipe made of rough material on the flow?
prajput
Ansys EmployeeHello @Kremella ,
The flow over a rough wall generally leads to higher levels of friction pressure losses.
July 31, 2020 at 1:39 pm
KR
AdministratorThanks for your response @prajput , Is there a way to calculate the friction losses?
July 31, 2020 at 1:40 pm
prajput
Ansys EmployeeYes, you can calculate the friction losses using the Darcy-Weisbach equation. The pressure losses are proportional to the length of the pipe and the Darcy-Weisbach friction factor:
delta_P / L = f_D * (rho / 2) * (V_avg^2 / D )
where,
delta_P - pressure drop
L - pipe length
f_D - friction factor
rho - fluid density
mu - fluid dynamic viscosity
V_avg - average fluid velocity
D - pipe diameter
This equation is valid for incompressible flows.
8762
4658
3151
1678
1456
