September 6, 2021 at 3:41 am
softaviator
SubscriberThe issue is of migrating 'C' Code into scade suite for which the logic needs to be converted as it is. Hence steps to efficiently implement For Loop in Scade Suite may be suggested.
September 10, 2021 at 6:25 amAubanel Monnier
I'm afraid there is no simple answer to your question: nature of the C and scade languages are quite different, they have different properties and expressiveness. Usually the right way to re-implement something from C to scade is to come back to the requirement and re-do the implementation from there. As an illustration of this principle, all the iterator constructs (map, fold, mapfold an friends) will generate for loops in C. But not all C for loops can be expressed in scade. If you are new to iterators you might want to start there:
All the best,
Aubanel.
Trending discussions- What are the OpenGL drivers supported by SCADE Display KCG?
- How to get event from Arinc
- What are the target supported to integrate SCADE Suite generated code?
- What are the OS supported by SCADE products for installation?
- Command or tool to extract information about input and output data associated to a specific node
- How does Medini calculate FITs based on mission profile?
- SCADE – FMU file
- Integrating C Code generated by KCG in Software Application
- ANSYS SCADE: The map iterator explained
- What is the most efficient way of implementing a FOR LOOP in SCADE Suite
7742
4502
2963
1449
1322
