What is the optimum range of wall y+ value for k-e model for eulerian boiling ?
    • matus
      What is the optimum range of wall y+ value for k-e model for eulerian boiling?
    • Karthik R
      Administrator
      Moving this post to the Fluids thread.
      This depends on which near-wall model you are using. If you are using the standard wall function, y+ ~ 30 should be good. Enhanced wall treatment will require y+ ~ 1 or lower.
      Hope this helps.
      Best,
      Karthik
    • matus
      Thanks Karthik
    • DrAmine
      For Wall Boiling using RPI based approach please use Near Wall Mesh with Yplus larger than 30-40.
    • matus
      Thanks Amine
Viewing 4 reply threads
