What is the reason for following error message when defining PML in an Acoustics model: All nodes of
October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeThis error message is due to extra nodes on the interface of PML elements. It’s recommended to use multibody part with “share topology” to generate continuous mesh.
Viewing 0 reply threads
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- What is cause of error: display time for result item greater than the step end time?
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
Top Contributors
2656
2120
1345
1118
461
Top Rated Tags
