what is the right way to interpret a UDF that computes a variable?
    • ChiaraCarlone
      I have a UDF to calculate OSI (oscillatory shear index) but in CDF i don't see the results about this variable.
      When I go to the UDM the values are only zeros. Ithink that there is a problem when I interpreted the UDF.
    • DrAmine
      Insert the pictures please. Also double check if the UDM fields are not zero in Fluent. n
    • ChiaraCarlone
      This is the UDF and I put the number of UDM locations on 1n
      Forum Moderator
      You've declared 5 UDM there, so setting it as 1 will cause problems. Also check as I think you want F_UDMI for wall values. n
Viewing 3 reply threads
  • The topic ‘what is the right way to interpret a UDF that computes a variable?’ is closed to new replies.
