May 28, 2022 at 11:55 am
adityarv2006
SubscriberI am designing an antenna array for a rectenna project. What is the unit for accepted power graph? Also is accepted power the same as the output power of the rectenna?
July 26, 2022 at 11:13 am
Anchal Singh
Ansys EmployeeHello Adityarv2006,
The unit for the accepted power of the antenna in HFSS is dB. You can go through the HFSS Help document and search for 'Accepted power' to know more about this topic.
Accepted power is the same as the output power only if the antenna is lossless.
Hope this helps.
Anchal
Ansys
- Maxwell, HFSS or Q3D?
- Error
3648
2534
1745
1226
578
