What is this error in Maxwell ANSYS
    • Mohammadmother
      Hi everyone,
      I am working on Maxwell version 17. I am going to simulate a simple PM machine to analysis 2D FEM. However, when I analyze the model, I see this error.
      "Maxwell2d solver, process solver2d error: Internal Solver Error: 'Transient solver handles only isotropic conductivity!'.
      I am thankful if you express me what is this error and how can I solve it.
      Regards
    • Jake
      Hello mohammad,
      I had the same problem as you. To fix this problem you need to right click on ANSYS Electronics Desktop 2017 and select "properties". Next select the "Compatibility" tab. Finally, you need to change the compatibility mode to windows 7.
      -j
    • Mohammadmother
      Thank you, Jake,
      I did your solution, but my problem has not been solved!
