August 7, 2018 at 5:16 am
KumarVaibhav
SubscriberCan someone tell me what is total velocity in explicit dynamics?What is its significance?Also i simulated a impact model of a rod hitting an object,i got the results but i cant see the rod actually hitting as i see on youtube videos for better enhanced presentation?Pls explain
both above
August 8, 2018 at 1:44 am
Subscriber -
August 15, 2018 at 2:31 am
Ananth Narayan
SubscriberWhat is the use of large result number of points. -
August 15, 2018 at 10:56 am
SubscriberThe large Result Number of Points is useful if you don't know exactly how fast the part might respond. With a large number, the deformation can be seen. Without, it is possible to wait hours for the before impact frame, and the after impact frame, but nothing in between. Then you have to wait hours to recompute the solution with more frames to see the impact.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2524
2066
1279
1096
457
