September 4, 2019 at 3:20 am
Bran
SubscriberHello,
I am new to Fluent and I am doing a simulation of an air conditioning unit supplying cold air to cool down batteries. I am setting boundary conditions for convection, but I was wondering what the significance of the wall thickness is?
What does adding a wall thickness impact? Is it a thickness for the fluid domain to interact with and how can I choose a suitable wall thickness?
Regards
September 4, 2019 at 9:38 am
Ansys EmployeeIf you look in the documentation it's explained in some detail. Very simply Fluent allows us to have infinitely thin walls to divide up geometry (ie a CAD surface can be used to bound a region). If you want to model conduction through the wall you need to give it a thickness and possibly turn on shell conduction.
In most cases the wall between the fluid & solid regions is left alone: also do NOT change anything from "coupled" unless you understand why you're doing it.
September 4, 2019 at 2:37 pm
Bran
SubscriberHi rwoolhou,
Thanks for your reply. My confusion comes from it being in convection settings, I did take a quick look at the documentation so I was confused whether that thickness was related to conduction.
So in this case, if I have heat generated in a battery, I set a source term of 20 W/m3. I want to cool them with an air conditioner inside a container. I set an inlet velocity and a cold temperature and then I can set a convection heat transfer coefficient in convection settings of the battery walls. If I want the heat generated inside the battery to conduct through the walls then I set a thickness in convection boundary conditions?
Otherwise, it will not take into account conduction, but the heat will still transfer via convection into the air?
Thanks again.
September 4, 2019 at 3:24 pm
Ansys EmployeeThat's an external wall: you set the convection coefficient for a surface that only has mesh on one side. The thickness is used to add a "skin" to a system where we don't want to mesh the casing.
Have a look in the tutorials included with the 2019Rx documentation as at least one will have wall thermal conditions set.
2524
2066
1285
1096
459
