What is wrong “The license used for the solution does not support a specified nonlinear material”?
    • si.sah
      Hi all I am getting this error:
      "The license used for the solution does not support a specified nonlinear material. Either use a higher level license, switch to linear material model, or suppress out the unsupported material nonlinearities."
      when I run Ansys Mechanical Ansys'21. Does anyone knows why I am getting this error?
      Thanks Ganem
    • Erik Kostson
      Most likely, the correct licence (say entreprise) is not being used.
      Try to set an enterprise license in WB/MEchanical:
      If this issue persists, then write to support or open up a new support request in the ansys customer portal, and we will be able to help.
      Thank you
      Erik
