November 11, 2020 at 8:54 pm
wyatt
SubscriberNovember 13, 2020 at 5:30 pmChris Quan
Ansys EmployeeMesh should be very fine to take the small wear amount into account. Failure model has to be applied to the material in Engineering Data to initiate the wear (material failure). Erosion model needs to be activated in Analysis Settings to remove the failed materials (Erosion by Material Failure = Yes).nViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- Explicit dynamics ERRORS
- turning simulation
- explicit dynamics
- Monte Carlo Simulation
- Error inside ANSYS LS Dyna: “An error occurred inside the SOLVER module: general error.”
8804
4658
3151
1680
1470
