August 29, 2023 at 10:53 am
Caleb Wood
SubscriberI am simulating water waves impacting a rigid structure and cannot figure out the parameters to use for EOS_LINEAR_POLYNOMIAL. All literature I look at use different values, and some papers only define C0 and C1 whereas others define C0 through C6. When I use these values my results are terrible. If, however, I choose to use EOS_MURNAGHAN my results look a lot better visually but my pressure readings which I am verifying against a paper are off.
Can someone explain to me why different papers use a different EOS_LINEAR_POLYNOMIAL if they are both simulating water? Also, would it be possible to provide me with the values for the EOS in the kg-m-s-Pa unit system? Thank you.
August 29, 2023 at 6:59 pm
Loic Ivaldi
Ansys EmployeeHello, if you can show me some papers I could have a better view.
Normally you can use this :
*MAT_NULL_TITLE
Water
$# mid ro pc mu terod cerod ym pr
2 1000.0 -10.0 0.001 0.0 0.0 0.0 0.0
*EOS_LINEAR_POLYNOMIAL_TITLE
Water
$# eosid c0 c1 c2 c3 c4 c5 c6
2 0.02.200000E9 0.0 0.0 0.0 0.0 0.0
$# e0 v0
0.0 0.0
Best Regards,Loïc
August 29, 2023 at 7:05 pm
Caleb Wood
SubscriberThank you, Loic. The paper I am trying to replicate can be found here: https://doi.org/10.1016/j.apor.2011.08.002
It examines waves impacting a plate in 2D using the SPH method. I am attempting to re-create it in 3D using either the ALE or S-ALE method. The model appears to be working well but the contact pressures are coming out 2-3 kPa to low.
August 29, 2023 at 7:30 pm
Loic Ivaldi
Ansys EmployeeTry with the eos parameter I gave you. You'll can try the murnaghan to speed up your run once the results with the eos_polynomial are satisfying. Also, try to refine the mesh to see if there is convergence between meshes.
Also, don't forget SPH and ALE are two different methods. When you use SPH, you use a *CONTACT_AUTOMATIC_NODES_TO_SURFACE between fluid and structure and it's totally different than the coupling in ALE with a *CONSTRAINED_LAGRANGE_IN_SOLID or *ALE_STRUCTURED_FSI so you will expect variation.
Best Regards,Loïc
- Explicit dynamics ERRORS
- explicit dynamics
- turning simulation
- Monte Carlo Simulation
- How to solve Energy error too large
7592
4440
2953
1427
1322
