Ansys Free Student Software
What resoultion should I use for the ansys
    • ada6991
      I need to use ansys for college and I have dell xps15 with 4k display
      I know ansys does not support 4k so what resolution should I use?
      When I open ansys workbench everything is tiny and the writing is one on top of another
    • ANSYS_MMadore
      Array Unfortunately, we do not support UHD and 4K resolution displays.nA workaround that others report as working fine is to reduce the resolution (try 1920 x 1080) and then also adjust your windows scaling settings. Reboot after making the resolution changes.nAlso try right-click on the ANSYS Product (Workbench in this case) shortcut and select Properties. Under Compatibility select Disable display scaling on high DPI settings.nn
