what should be the mesh & setup for Chamber of submersible pump and it’s closed impeller?
    • Nisarg
      my chamber of submersible pump is ready and the face of chamber which is towards motor to the impeller starting face towards shaft end face is having distance of 27.9mm which is inside of chamber. i gave mesh and for setup i am having only outlet parameters like Discharge,rotation speed of impeller & head.so what should be the mesh and setup of it?n
    • Nisarg
      Respected sir,can you please help me to overcome this situation because i don't know where is the problem while i am doing parametric for grid independence my head and efficiency is fluctuating so want to clear my input condition,nThank you.n
    • RK
      Hello Nisarg, nTo start with, you can go over the Fluent tutorial for modeling the centrifugal pump : https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/flu_tg/flu_tg_pump_volute.htmlnn
