What should I use contact or joint
    • ashishchache
      I am doing a static structural analysis of plastic hinge. I am new to ansys I do not know should I use contact or revolute joint between pin and hinge leaf .
      Also
      1) is it good to use both at same place ( frictional contact and revolute joint) what do you think ?
      2) how torsional stiffness and torsional damping value useful to that joint ? (Are they necessary to use )
      When i use frictional catact between two leafs & right leaf and steel pin, and boned contact between left leaf and pin.????
      Equivalent (von misses ) stress
      When I used a fixed  joint between left leaf and pin , revolute joint bet right leaf and pin and frictional contact between both leafs of hinge.????
      Equivalent (von misses)stress
      why a value of equivalent stress increased when I used joints or decreased when I used contacts ?
Viewing 0 reply threads
