November 20, 2017 at 7:38 am
Jimmyhan
SubscriberHi, I am Jimmy. there is a problem in my simulation, When I used solver there is a warring stop my simulation. it told me something wrong in symmetry boundary setting. So I followed the suggestion to check the reason. But till now I can not find it out. So I try to use another way. I change the cross-section setting to a periodical boundary. It is work! I would like to know this interesting thing. 1. What the difference between the symmetry boundary and periodical boundary? 2. What kind of situation the symmetry boundary (or periodical boundary) have to be used? 3. How can I understand the symmetry and periodical boundary warning and the suggestion clear?Maybe you can give me some advice directly on my problem. Thank you!
November 20, 2017 at 12:28 pm
November 20, 2017 at 10:57 pm
Jimmyhan
SubscriberYour reply was such great and clear. But can you give me some advice, Why I change symmetry boundary to periodical boundary the solver was no warning? Symmetry boundary recognize there no plane or axial, but periodical boundary was ok. is there some limitation in boundary setting?Thank you so much.
November 20, 2017 at 11:17 pm
Min Zhang
SubscriberSorry, I do not know your geometry. Maybe you can refer to the information on this website:
https://www.cfd-online.com/Forums/cfx/65276-symmetry-boundary-conditions-cfx-3.html
November 21, 2017 at 1:57 am
Jimmyhan
SubscriberThank you, Your suggestion really helps!
- The topic ‘What the different between the symmetry boundary and periodical boundary’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
