June 21, 2022 at 7:10 pm
javat33489
SubscriberHi everyone.
What to do if the rubber penetrates into a rigid body during compression?
My task number 1 is this: the first step is an interference fit with the help of ekill, the second stage - the rubber is straightened with the help of elive, the third stage - the rubber is compressed under a pressure of 35 MPa. The rubber has a fold, and at about 5 MPa compression, an error occurs due to the penetration of the rubber into each other at the fold. I used all life hacks, tried normal lagrange. Nothing helps, what should I do? Help. Here is my contact where the rubber fold is:
scr
My problem number 2 is this, the rubber is compressed in two directions to a solid body and also penetrate into it. I tried all the life hacks, it did not help either. Here is my contact for this task:
scr
Hope it helps, thanks.
June 21, 2022 at 7:13 pm
javat33489
SubscriberMy pictures are not loading
December 6, 2022 at 5:57 am
bhagwantP
Ansys EmployeeHello javat33489,
I can't find any description image of the question that you posted. Can you please try to attach image again?
Thanks
3744
2573
1797
1236
594
