November 19, 2020 at 2:44 pm
abbas
SubscriberHello,nnI am working both on Fluent and CFX and I know that there are some algorithms for Pressure-Velocity Coupling Method for example SIMPLE, PISO, Coupled. Which type of algorithm does CFX use?nAnd based on my understanding, CFX uses a pressure based solve while Fluent uses pressure based and density based solver.nnBest regardsnAbbasn -
November 19, 2020 at 3:04 pm
DrAmine
Ansys EmployeeANSYS CFX uses A Coupled Solver. nn -
November 19, 2020 at 6:10 pm
abbas
SubscriberThanks Amine for the response. Is it correct that CFX uses pressure based solver? Because I couldn't find ant information about that.nnBest regardsnAbbas Aghagoli n -
November 19, 2020 at 6:40 pm
DrAmine
Ansys EmployeeYes. That is true!n
- The topic ‘What type of algorithm does CFX use?’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3151
1680
1470
