January 20, 2021 at 7:34 pm
kavatar
SubscriberHello Everyone,
I want to understand the similarities of magnetic transient and eddy current solution for an AC problem (Rotating magnetic field problem). I think, if I run transient solution for longer time then it will reach at a steady state and solution for the last current cycle would be similar to the eddy current solution.
So here Is the description of query --
I applied 3 Phase current to six coils to get rotating magnetic field. To this end, first, I get coil and stator arrangement from SRMCore. I split them and assign material to each coil and core.
By applying section to the coil I get planer ports to make coil terminal. The attached image show coil terminals (each having 34 conductors) with current direction.
January 22, 2021 at 10:54 amViewing 1 reply thread- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
5454
3419
2473
1310
1022
