WHAT’s the problem
    • sdh123
      HI!
      Whenever i try to run solution, i keep receiving a message says, " The ANSYS CFX solver exited with return code 1. No results file has been created." and also another one says," Update failed for the Solution component in CFX.  The solver failed with a non-zero exit code of : 2,"
       can someone tells what the problem is?
      Thank you.
      Looks to be a licencing issue: read the top section. Which version (eg 2019R3) and install (student, academic etc) are you using?
    • sdh123
      I'm using ansys student 2019R3
      Odd, did you install as Admin? Please can you post a screen grab of CFX-Pre?
Viewing 3 reply threads
