March 11, 2021 at 4:15 pm
maurya
SubscriberHello sirn How to use different strain rate for different material in same modal.nFor example Aluminum, steel and Carbon fiber are there, all are having different strain limit.nPlease guide me.nThank youn -
March 17, 2021 at 8:26 am
1shan
Ansys Employee,nDo you want to delete elements from different materials after they reach their respective strain limits? You could do this using the EKill option. Chech this https://simutechgroup.com/performing-ekill-element-death-in-ansys-workbench-mechanical-model/.nnRegards,nIshan.n -
March 18, 2021 at 1:25 am
SubscribernDoes EKill work with the Explicit Dynamics solver?n -
March 18, 2021 at 2:50 am
maurya
SubscriberHello sir peteroznewmann I did not try it, today I will. I will inform you as I will try.nThank you for your anticipation.nn -
March 18, 2021 at 6:31 am
1shan
Ansys EmployeeHi Array,nNo, I don't think the APDL code snippet would work for Explicit which uses Autodyn. My bad!! I thought the simulation is being run in transient. Array In explicit you could set up failure strain limits for each material and then use on material failure under erosion setting. Am I right Peter?nRegards,nIshann -
March 18, 2021 at 11:09 am
Subscribernhas written what I expect is required to have failure occur at individual material limits.n -
March 19, 2021 at 5:23 am
March 19, 2021 at 11:48 am
SubscribernChange the highlighted Yes to a No.n -
March 29, 2021 at 3:57 pm
maurya
SubscriberHello sir @peteroznewmann When I changed it to No, I am not getting the option where to fill the Strain limit to other material. nOr it take the values from the engineering data.nthank younn -
March 29, 2021 at 5:53 pm
SubscribernIt takes the values from properties for that material in Engineering Data.n
Viewing 9 reply threads
Trending discussions
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
Top Contributors
2630
2104
1327
1110
461
Top Rated Tags
