When can I assume that a process is steady state?
    • Keyur Kanade
    • Karthik R
      Administrator
      In systems theory, a system or a process is in a steady state if the variables (called state variables) which define the behavior of the system or the process are unchanging in time.
    • prajput
      To add to @kremella 's response...Certain unsteady processes can also be approximated as steady ones. For example if the variation if the variables over time is small a process can be assumed to be steady state.
      Under this assumption the time derivative in the governing equations can be neglected and the analysis is simplified.
