July 31, 2020 at 1:49 pm
prajput
Ansys EmployeeWhen we say "the time period of a wave is 4 s" what does that mean? Does it take 4 s to travel a certain distance (say 1m)?
Karthik R
AdministratorEvery wave undergoes periodic or cyclic motion. The time required to complete one cycle is referred as the time period of a wave. So the statement means that components of the wave take 4 s to complete an entire cycle.
July 31, 2020 at 1:50 pm
Keyur Kanade
Ansys EmployeeThe second part of your question actually refers to the velocity of the wave. So if a wave took 4 seconds to travel 1 m, its velocity would be 1/4=0.25m/s. But the time period of 4 s does not give any information about the velocity of the wave (unless you know the wavelength of the wave in which case velocity=wavelength/time period of the wave)
- What is the difference between internal and external flows?
- How do you define specific gravity? What is its significance???
- Why is it much easier to roll a log than drag a wood cube with the same mass?
- The level of water inside the straw was higher than the level of water in the beaker
- What is the surface tension of a fluid?
- How to gain research experience?
- Whats the difference between sensible heat and latent heat?
- Cell Counting?
- Why does the total sum of forces acting on a system always have to be equal to zero?
- Why ice floats on water
2706
2142
1357
1144
462
