Where should I place the boundary conditions?
    • marhark92
      I am trying to conduct FEA on fish skulls, but apparently I when I place the fixed support on rear end (image below), the maximum stress is found on it. Previous literature set the rear end of the skull to be the fixed support when applying loads forward to the front end of skull. I attached screenshots of the Results with the fixed support established on the rear end. Please advise. Thanks!
    • Saumadeep
      The image that you attached doesn't give an appropriate idea of the boundary conditions. Can you provide a better idea by attaching images showing the following:
      The boundary conditions
      The load applied
      And also can you briefly explain what is the analysis about and how it is set up.
      Thanks,
      Saumadeep
      Ansys Help
      Ansys Learning Forum (Rules & Guidelines)
