November 16, 2020 at 2:07 am
Fernando Torres
SubscriberR.paper states Silicon's fracture strain is kept as 0.01. Where to put this value of fracture strain in my material model ? I've almost used every other value provided by the author. Thanks. n -
November 19, 2020 at 2:13 pm
Aniket
Forum ModeratorCan you please give some more information about the problem? Which software are you using?n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn -
November 20, 2020 at 1:15 pm
Fernando Torres
SubscriberI'm trying to simulate silicon cutting with diamond tool. I'm using AUTODYN. In engineering data, I was unable to put fracture strain limit of 0.01of silicon (there is no direct variable as 'fracture strain' in engineering data) while creating a material model for silicon. Thanks.n
- The topic ‘Where to add fracture strain value of 0.01 of silicon’ is closed to new replies.
- Maximum Time Step
- Error 20211 (STR+211) while 2D impact analysis
- ls dyna has no solver
- LS-Dyna Prestressed
- Whereabouts of the LS-DYNA program manager
- License error : NO SUITABLE FEATURE FOUND
- Total Contact Force and Contact Pressure
- Contact not working in Ls-Dyna and Ls-Dyna ACT (WB)
- Element direction..
- TIED_CONTACT for Shell Elements – Gap between Shell-Shell and Shell-Solid
8808
4658
3155
1688
1478
