Where to put VFOPT command
    • solani
      Hello eveybody
      Because of changing geometries in my simulation I need to use the VFOPT command but I am not sure where to put this command. Can anyone help?
      Here is my code so far:
      SF,InnerInsulationSurface, rdsf,0.9,1 ! radiation settings
      SPCTEMP, 1, 22 ! ambient temperature in case enclosure is open
      stef,5.67e-8 ! stefan boltzman constant
      toffst,273.15 ! temperature offset
      VFOPT, new !forcing new calculation of few factors
      hemiopt,10 ! resolution of view factor calculation
      tunif,22 ! initial temperature
      Thank you for your help
      Ani
    • Erik Kostson
      Hi
      You would need to add an apdl command object under the thermal solution and use it for all load steps:
      See here for some info:
      Thank you
      Erik
    • solani
      Thank you Erik for your very very fast reply. I selected the wanted step for my APDL command. But now I am a bit confused: What are load steps? Equals the number of load steps to the number of Number of Steps that you can control in the Analysis Settings?
      However what I wanted to ask in my post is the following: Does it matter where I put the VROPT command? So like this
      stef,5.67e-8! stefan boltzman constant
      toffst,273.15! temperature offset
      or like this
      I know from Python or Java that the place in the code matters. I thought it would be the same for Ansys. Therefore my question is where to put the VFOPT command in the code.
      Thank you again in advance.
