November 2, 2023 at 1:59 am
mmia1
SubscriberHi
I am planning to use beam element to model my pipes which will experience large deformation. Does anyone know which beam element Hughes-Liu vs Belytschko-Schwer available in LSDyna will be good for large deformation analysis?
November 2, 2023 at 1:50 pm
Jim Day
Ansys EmployeeI think it’s safe to assume that nonlinear material behavior accompanies the large deformation in your application. H-L beams are integrated beams; B-S beams are resultant beams. I would recommend Hughes-Liu beams for a number of reasons, including being able to specify the cross-section shape and number/location of cross-section integration points and also having access to a wider variety of nonlinear material models.
- Maximum Time Step
- Error 20211 (STR+211) while 2D impact analysis
- ls dyna has no solver
- LS-Dyna Prestressed
- Whereabouts of the LS-DYNA program manager
- License error : NO SUITABLE FEATURE FOUND
- Total Contact Force and Contact Pressure
- Contact not working in Ls-Dyna and Ls-Dyna ACT (WB)
- Element direction..
- TIED_CONTACT for Shell Elements – Gap between Shell-Shell and Shell-Solid
8808
4658
3153
1688
1478
