Which boundary condition is appropriate one for a bolt joint between bracket and motor
    • kamalkrishna
      Which boundary condition is appropriate one for a bolt joint between bracket and motorn
    • kamalkrishna
      For Modal Analysisn
    • Rahul Kumbhar
      There are multiple options: You can use beam connection, fixed joint or Bonded contact. The beam connection can be created from Connection>>Insert>>Beam. You can also use MPC formulation inside the bonded contact.nIf you are planing to capture prestressed effect, you can run static analysis first with bolt pretension load and then run Modal analysis on it.n
