April 22, 2021 at 2:28 pm
Chris Kopetski
Ansys EmployeeIn TWLM these effects are included through various recombination rates in the laser rate equations. We do have another solver called CHARGE, which is a 2D/3D finite element drift diffusion solver with standard mobility and tunneling models. While CHARGE does not model laser emission physically, it does have a stimulated recombination model and the parameters of this model can be populated from the TWLM simulation. Find more details about the model in section Stimulated recombination here: nThe user can plot IV curves, 2D/3D current density, electric field, and others. Here's an example of using CHARGE for LIV laser simulation.nnQuestion migrated from the Lumerical Knowledge Exchangen
Simulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Error on Lumerical device
- Lumerical support has moved to the Ansys Learning Forum (ALF)
- focusing efficiency
- How to perform optimization over terminal in linux without GUI?
613
560
220
188
128
© 2022 Copyright ANSYS, Inc. All rights reserved.
