March 21, 2022 at 4:22 pm
tandinhtamky
SubscriberHi there,
I'm working for this simulation. This model include 2 cylinder (battery cells) with heat source in side. Air domain with velocity inlet = 2m/s, temperature = 300K.
I have already control the y+ at wall of cylinder below <1.
As I know, I use K-w SST, and SIMPLEC, second order upwind, but the residual not descent below 10e-6 (even 10e-3).
I'm quite sure about quality of mesh. (min orthogonal quality >0.16)
So, what should I use turbulent model ?
Thank you so much.
March 21, 2022 at 6:46 pmDrAmine
Ansys EmployeeSst model is the model of choice. Coupled solver is recommended.
March 22, 2022 at 2:55 amtandinhtamky
SubscriberHere is my new setup.
I'm nervous about time step size, is it good ? because now I want to simulate the discharge process of battery in 3600 second (1 hour).
Coupled scheme with second order upwind.
Solution control here:
But, the residul (continuity) just about 1e-2 (orther ~1e-3). And, I also check velocity inlet plot -> value become constant. And I also check in the fluxes in the results, about mass imbalance, total heat tranfer rate -> that's ok.
So, my simulation now is convergence or not, Sir ?
March 22, 2022 at 11:20 amRob
Ansys EmployeeWe typically set a time step so the flow crosses a cell in roughly 10 time steps and then adjust to converge each time step in 10-15 iterations. There are a few transient tutorials in the Help system so have a look through those for some more guidance.
March 22, 2022 at 12:26 pmDrAmine
Ansys EmployeeYour time step is very enthusiastic and can understand why you are so nervous about it. A good rule of thumb to have a time step corresponding to delta_t= (minimum over all cells of cell volume of 10*CellVolume^0.333/maximum Velocity)*10 (using her CFL = 10 for quick runs. You can increase it to even higher values if things are stable).
March 22, 2022 at 2:18 pmtandinhtamky
SubscriberThanks for replying me !
But, I don't quite understand what you mean about delta_t formula. What is "minimum over all cells of cell volume of 10" ? And Cell volume is max or min or average value ?
Also, I switch viscous model to RNG k-e enhance wall function, still coupled method but flow courant number I descent from 200 to 50. Time-step-size still 10 second. Below is residual.
Is it convergence, right ?
March 22, 2022 at 3:37 pmMarch 22, 2022 at 9:20 pmDrAmine
Ansys EmployeeJust look after CFL number and you will understand my reasoning, ƒÿÇ.
March 22, 2022 at 9:24 pmDrAmine
Ansys EmployeeJudging convergence will also need to consider behavior of couple of monitored quantities and imbalances. Only residuals looking is not enough: you any hmway have now low global scaled continuity residual for example which does not automatically 100% confirm that solution towards end if time step is not changing but it tells that likely it won't change: u should verify that for this very simple exercise.
March 22, 2022 at 9:25 pmDrAmine
Ansys EmployeeMesh can be created with ICEM CFD or Ansys Meshing.
Viewing 9 reply threads- You must be logged in to reply to this topic.
2688
2138
1349
1136
462
