May 31, 2022 at 10:32 pm
wcai05
SubscriberI was looping through these python scripts for interconnect simulation. However, the software will automatically shut down after tens or so iterations. It does not make sense to me cause I have tried adding pauses and clearjobs instructions but does not seem to help solve the issue. I wonder what else should I try?
The attachment shows the looping script I was running.
July 19, 2022 at 10:07 pm
Guilin Sun
Ansys EmployeeI am not sure if you have the proper interop license. Please check. If you have, please first test the INTERCONNECT file works independently. You can also test the loop using script to make sure that this issue is not from INTERCONNECT but from the interop license or Python.
- Error on Lumerical device
3876
2639
1859
1262
606
