August 10, 2019 at 3:51 am
nagarajan.dharanibalan
Subscriber -
August 12, 2019 at 2:43 am
August 12, 2019 at 9:07 am
Subashni Ravichandran
Ansys Employee -
August 13, 2019 at 3:22 am
SubscriberHi Subashni
I have used below template. Between fluids and solids i have selected since I need to understand effects on outer pipe due to thermal. Flow of thermal is air which is travelling through internal diameter of the pipe.
Apart from above point, I have quires,
Still I got confused with your templates, if I'm able to create the work flow so that i can define myself manually on all those constrains. Is it possible in AIM?
August 13, 2019 at 11:19 am
Ansys EmployeeHello Nagarajan D
I'm sorry but you will need to choose a template so that appropriate options can be presented for the analysis.
I would recommend you go through the second and third videos on the Discovery AIM: Fluid Flow Tutorials page. They are in-line with your simulation interests.
For better understanding of the various features in Discovery AIM, I would suggest you go through all the short tutorial videos on the Discovery AIM: Tutorials page.
You can also browse through the several application examples or use the search tab on the top to search for the required topics.
- Can’t see license on online account
- loss of user settings
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
3744
2573
1793
1236
594
