January 21, 2022 at 10:37 pm
mmt
SubscriberI am trying to get the bell-shaped Cp vs TSR graph in my 2D simulation of the H-Darrieus vertical axis wind turbine (using a sliding mesh model). However, I am always getting an ever increase of Cp value with the increase of TSR value i.e. the more I increase the value of the angular velocity of the sliding mesh, the higher the moment coefficient gets. What am I doing wrong and how can I get the bell-shaped curve?
January 24, 2022 at 11:11 amRob
Ansys EmployeeAssuming it's set up and you're monitoring the correct value with the correct axis can you check it's not just that you've not reached the peak? Pictures will help.
January 24, 2022 at 9:20 pmmmt
SubscriberDear sir I am trying to replicate the results of a paper, so it's unlikely that the peak will be far-off. Here's a picture that shows the paper's results, experimental results, and my result. I am trying to get the transition SST model and according to the paper, it is run at inlet velocity 10m/s:
This is what I have been doing:
I have taken a very simple mesh. I have followed the tutorial of confluence (I replicated both the transient and steady parts. This is the link:https://confluence.cornell.edu/pages/viewpage.action?pageId=333371302)
So far I have understood, to get the Cp vs TSR curve, I have to change the turbine's angular velocity here:
This is run at 176 rev/min i.e. 18.4307 rad/s. For 10m/s inlet, the TSR will be (omega*turbine Radius)/freestream Velocity=(18.4307*1.125)/10=2.30.
This way, for each TSR point, I have to run the simulation and get the average moment coefficient value(Cm):
Then, I calculated Cp=Cm*TSR. This way I calculated but always got an increasing value of Cp.
Please let me know if I am making mistakes and how I can fix this.
Thank you.
January 25, 2022 at 9:36 amRob
Ansys EmployeeTo confirm, the system spins anti-clockwise? Please post some contour plots.
January 25, 2022 at 10:57 pmJanuary 26, 2022 at 9:33 amRob
Ansys EmployeePost process in Fluent and zoom in on the areas of interest. Looking at the image you have a local acceleration around the object: is the domain large enough to avoid channelling the flow through the VAWT?
January 26, 2022 at 9:54 ammmt
SubscriberSir,
I have made the geometry based on the paper, so I always assume that my geometry is okay. However, the radius of the ring circles was not provided, but the mentioned it is expected to be as narrow as possible and that is what I did. Should I bring any change to the geometry?
January 26, 2022 at 11:56 amRob
Ansys EmployeeIf the cell size isn't too dissimilar over the sliding interface then the position isn't too critical other than to avoid artificially squashing cells near the blades. The area of interest is the domain sides as there looks to be an acceleration caused by the VAWT blocking the flow.
How did they define the blade shape in the paper?
January 26, 2022 at 12:19 pmmmt
SubscriberSir I'm not sure what you exactly mean by "define the blade shape". It's NACA 0015 airfoil. I am attaching the paper. I am working on rotor A as mentioned in the paper.
January 26, 2022 at 2:57 pmRob
Ansys EmployeeYou have built the blade shape based on something, ie the paper. Is it the right shape, and have you resolved that shape (and wake) in the mesh?
January 28, 2022 at 5:27 ammmt
SubscriberSir,
Yes, I have drawn the shape based on the paper. I have taken the coordinates of NACA 0015 from NASA's website and my geometry is 2D.
March 21, 2023 at 3:00 pmTarun mutyam Pichikala
SubscriberSir, I am doing analysis on Archimedes wind turbine in ansys fluent here my problem is torque is increasing with speed of the turbine because I’m not getting the that curve in cp vs tip speed ratio graph instead of that I am getting inclined line could please help me how to overcome this problem
March 21, 2023 at 3:03 pmRob
Ansys EmployeeHave you defined the axis correctly?
March 21, 2023 at 3:16 pmTarun mutyam Pichikala
SubscriberYes, My turbine is rotating about x axis so I gave 1 0 0 to take moment about x axis. At orgin
March 21, 2023 at 3:46 pmTarun mutyam Pichikala
SubscriberI am waiting for your reply sir
March 21, 2023 at 4:15 pmRob
Ansys EmployeeIf you keep increasing the wind speed and don't change the rotor speed to match why wouldn't the force increase.
As an aside, bumping a thread after 30minutes isn't going to speed up an answer. It is likely to annoy people. After a couple of days is fine, unless those days are weekend.
Viewing 15 reply threads- You must be logged in to reply to this topic.
3694
2558
1765
1234
590
