TAGGED: ansys-fluent, error, fluids, heat-transfer, meshing
February 4, 2022 at 8:32 pm
brb40
SubscriberI received this error when I was performing a mesh independence study. I was able to successfully run the first iteration (convergence with residuals, the mass flow was conserved, and the exit temperature reached a steady-state), but when I refined the mesh and attempted to re-run, I was given this error. I have researched some common causes online, such as making sure there is not a percentage in the folder name, but that is not the case. I've attached a picture of the error in the command window.
February 7, 2022 at 2:27 pmKarthik R
AdministratorHello What is your mesh quality on the new mesh? Also, are you reading this mesh on a fresh instance of Fluent?
Karthik
February 8, 2022 at 12:19 pmRob
Ansys EmployeeThe skew in that mesh is going to be horrible, but I wonder if the error is on opening the solver not reading the mesh. Can you post more of the text, you can expand the TUI window to do this.
5290
3311
2471
