November 13, 2020 at 7:59 pm
John Doyle
Ansys EmployeeThe time hardening creep models can sometimes be very challenging to converge because the time component can overwhelm the stress dependence - time marches on but the material algorithm can only adjust the stress to find the correct value of creep strain. For example, if a generalized time hardening is ecr = C1*sigma*t^r, then if t^r is large the material algorithm needs for find a very small value of sigma so that the creep strain is small enough to satisfy the constitutive equation. n The general guidance is that the time hardening formulations work best in constant stress or when the loading in the simulation is close to the experimental loading.n -
December 4, 2020 at 3:55 pm
Govindan Nagappan
Ansys EmployeeThank you for sharing this informationn
- The topic ‘Why are time hardening creep models so challenging to converge sometimes?’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
