November 2, 2018 at 6:52 am
LY616
SubscriberWhy can't my ANSYS maxwell16 contact with ANSYA workbench16? I install ansys workbench first and then install maxwell16. But the problem is that I could not finish the Coupled field analysis using the workbench and maxwell. The maxwell16’s default point that it could contact with ANSYS14.5. Please tell me how to solve them. I am so appreciated for you help
November 2, 2018 at 11:50 am
Ansys EmployeeThe ANSYS and (formerly) Ansoft products had a different numbering scheme so direct connection wasn't always as simple as it ought to be. If you download the R19.2 software things should work more smoothly.
November 3, 2018 at 4:30 am
LY616
SubscriberThank you very much for your reply. I wonder where I can download the R19.2 software,could you give me a URL or send to my email(yiliyi616@163.com). I am very appreciated for your help.
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
457
