February 9, 2023 at 4:17 am
abhnv_01
SubscriberI am trying to simulate a heat pipe in (2D) which has three sections:
Evaporator - Constant heat flux (boundary conditions)
Condensor - Constant temperature (boundary conditions)
Adiabatic section - Zero heat flux (boundary conditions)
I am using VOF multiphase model -> Evaporation - condensation model -> Lee model.Transient simulation with gravity and implicit body force formulation.
Time step size = 0.0001 (1E-04).
The simulation works well for first 10000 time steps (1 seconds of flow time) and then this error where global courant number exceeds 250.
But here is a mystery, the simulation runs well with constant temperature boundary condition at the evaporator.
I want results with constatn heat flux, I am not able to track the error, any help will be highly appreciated.
February 9, 2023 at 10:08 am
Ansys EmployeeReport the surface temperature around the point the solver fails. I assume you've read and understood the implications of the heat flux and temperature wall boundary?
February 20, 2023 at 10:48 am
abhnv_01
SubscriberI have read the about both the boundary conditions.
But if you can enlighten about it, then that would be great.
Thanks in advance.
February 20, 2023 at 12:13 pm
Ansys EmployeeIn what way? What wasn't clear from reading the documentation?
February 20, 2023 at 12:18 pm
abhnv_01
Subscriberfrom the documentation, I have read that both the boundary conditions use the same heat transfer equation.
My simulation works well with constant temperature but fails with constant heat flux.
So, I cannot detect the reason for the difference here.
February 20, 2023 at 1:28 pm
Ansys EmployeeOK. With a constant temperature the heat flux floats to fix the wall temperature. With a fixed flux the temperature floats. But.... In regions with poor heat transfer the wall temperature may become high to force the fixed heat flux. If that alters the material density in any way the solution may become unreasonable, ie buoyancy forces are excessive. A better boundary option may be convection, but that's for you to decide.
3812
2593
1849
1244
600
