Why do I receive “Output is not available at current design point” in Workbench?
    • agarwa20
      I am performing a design of experiments scheme for a Maxwell 2D simulation in Workbench. Even though I simulate a valid design point and obtain the output in Ansys Electronics Desktop separately, Workbench gives an erorr.
    • Navya C
      Hi @agarwa20,
      I can suggest you the following checks based on the information provided by you.
      1. Open Maxwell and see if the simulation is completed without any errors.
      2. Check if you need to update/refresh any elements on the workbench to make sure every block is updated with a green check.
      3. If your problem is not solved, share some screenshots of how it is implemented in Workbench
        Regards
        Navya
