November 21, 2019 at 8:33 am
charlesk
SubscriberHello everybody,
I’m doing fracture analysis on steel structures mostly using the premeshed-crack option in ANSYS workbench (I used the arbitrary crack before and had the same problems). Due to the fact that I have to do many iterations to calculate the crack propagation, modelling every iteration with crack tip elements does not seem feasible. Using the “semi-elliptical crack” is not an option because my crack will propagate close to the border of the steel part later.
My main problem is this: when refining my mesh around the crack the SIF (K-Values) keep getting better until a certain element size. From then on, the results get worse and worse again. This does not count for the non-fracture-tool-results (stress, strain, deformation, ...)
I’m modelling my crack by extruding and then deleting a very thin (0,001 mm) semi-elliptical surface from my body. Afterwards I use the pinch command to ignore the small face within the crack. I’m meshing my whole body using quadratic tetrahedrons.
Right now I’m working with ANSYS 19 R2, I have encountered the same problem in other versions aswell.
I added some pictures showing the geometry around the crack and the mesh after deformation. I can upload more information if needed.
Thank you!
3299
2469
