March 4, 2022 at 10:01 am
kmd14
SubscriberScenario: My simulation comprises 4 bodies. This can be imagined as 4 cylinders encasing each other (please note the geometry is more complex than a cylinder, they are asymmetric. The centre-most body is bonded to body2, body 2 is bonded to body 3, then body 3 and body 4 are considered frictional (with CoF ~0.5). A load is applied to the top face of body 1, and the bottom face of body 4 is fixed.
Some of my simulations have run fine displaying pressure/ frictional stress (all the simulations I am running are very similar, they just have slight geometric alterations i.e., cylinder size of body 3 may vary slightly, or angle of bodies 1-3 inside body 4 may differ). But the contacts/setup are very similar, and majority run but some of my recent ones appear to have '0 pressure'. I can also confirm that my simulations have converged, so I'm running out of options on new things to try. I specifically need pressure as opposed to just using SX, SY and SZ (or normal stresses) as my surfaces are curved / asymmetric.
- Why is this happening?
- How can I overcome this issue? I've tried playing with the settings, although this wasn't necessary before so I don't know why it would be now (i.e. I have tried flipping the contact/target directions, tried updating stiffness from programme controlled to 'each iteration', played with mesh contact size)
Any advice on how I can fix this would be much appreciated. I can see any other result on the named surface, just not pressure, which is the main thing I'm interested in.
Thanks in advance!
March 4, 2022 at 4:13 pmAniket
Ansys EmployeeCan you please insert some inline images describing the problem in some more detail?
-Aniket
March 7, 2022 at 8:25 amViewing 2 reply threads- You must be logged in to reply to this topic.
2656
2120
1347
1118
461
