Why do parameters not appear in workbench when using external type excitation in Electronics Desktop
March 7, 2022 at 4:02 am
agarwa20
SubscriberWhen using external circuit type using Maxwell circuit editor, the default design Xplorer setup is not available under Optimetrics in Ansys Electronics Desktop, and the parameters do not appear in Workbench. What is the way around this?
March 9, 2022 at 2:49 pmDeyu Li
Ansys EmployeeMarch 9, 2022 at 4:33 pmagarwa20
SubscriberHi Thank you!
- Maxwell, HFSS or Q3D?
- Error
2726
2146
1357
1150
462
