why does 2 link manipulator with fixed and joint support has the same results in modal analysis?
    • Amirmkr
      I have defined a 2 link manipulator using mpc184 between the 2 beams. In one problem I have defined fixed support in the following code:
      /PREP7
      ET,1,BEAM188
      ET,2,MPC184
      KEYOPT,2,1,6
      KEYOPT,2,4,1
      MPTEMP,1,0
      MPDATA,DENS,1,,7830
      SECTYPE,1,BEAM,RECT,Beam01,0
      SECDATA,0.01,0.01,2,2,0,0,0,0,0,0,0,0
      MPDATA,EX,1,,2.068e11
      MPDATA,PRXY,1,,0.3
      LOCAL,11,0,1,0,0,0,0,0,1,1,
      SECTYPE,2,JOINT,REVO,Joint1
      SECJOINT,,11
      CSYS,0
      N,2,0,0
      N,3,0.5,0
      N,4,1,0
      N,5,1,0
      N,6,1.5,0
      N,7,2,0
      TYPE,1
      SECNUM,1
      E,2,3
      E,3,4
      E,5,6
      E,6,7
      TYPE,2
      SECNUM,2
      E,4,5
      D,2,All,0
      ANTYPE,2
      MODOPT,LANB,10
      EQSLV,SPAR
      MXPAND,10, , ,0
      LUMPM,0
      PSTRES,0
      MODOPT,LANB,10,0,0, ,OFF
      FINISH
      /POST1
      SET,LIST
       In the other problem I have defined a joint support in the following code:
      /PREP7
      ET,1,BEAM188
      ET,2,MPC184
      KEYOPT,2,1,6
      KEYOPT,2,4,1
      MPTEMP,1,0
      MPDATA,DENS,1,,7830
      MPDATA,PRXY,1,,0.3
      LOCAL,11,0,0,0,0,0,0,0,1,1,
      SECJOINT,,11
      LOCAL,12,0,1,0,0,0,0,0,1,1,
      SECTYPE,3,JOINT,REVO,Joint2
      SECJOINT,,12
      CSYS,0
      N,1,0,0
      N,2,0,0
      N,3,0.5,0
      N,4,1,0
      N,5,1,0
      N,6,1.5,0
      N,7,2,0
      TYPE,1
      SECNUM,1
      E,2,3
      E,3,4
      E,5,6
      E,6,7
      TYPE,2
      SECNUM,2
      E,1,2
      TYPE,2
      SECNUM,3
      E,4,5
      D,1,All,0
      ANTYPE,2
      MODOPT,LANB,10
      EQSLV,SPAR
      MXPAND,10, , ,0
      LUMPM,0
      PSTRES,0
      FINISH
      /POST1
      SET,LIST
      Why do both problems give the same natural frequencies?
    • Amirmkr
      Even if you put
      D,2,ux,0
      D,2,uy,0
      D,2,uz,0
      D,2,rotx,0
      D,2,roty,0
      to the first case you will get the same results.
