Ansys Products
Ansys Products
Why does my SCCM application keep returning error 0x80091007(-2146889721)?
    • vendeville_lj
      I'm trying to get a SCCM application for ANSYS 2021 R1 up and running, but the installation keeps failing with error 0x80091007(-2146889721). If I run the script from the same network location the SCCM application is pointed to, the program installs properly and without incident. Some of the things I've tried:
      Redistributing the application; no change to the error.
      Re-validating the application; no change.
      Re-creating the application; works on the first couple of test machines, but fails on subsequent installation attempts.
      The script I've been using is:
      \networklocationANSYSANSYS2021R1setup.exe -silent -licserverinfo 2325:1055:licenseserver
      echo Set oWS = WScript.CreateObject("WScript.Shell") > CreateShortcut.vbs
      echo sLinkFile = "C:UsersPublicDesktopANSYS Workbench 2021 R1.lnk" >> CreateShortcut.vbs
      echo Set oLink = oWS.CreateShortcut(sLinkFile) >> CreateShortcut.vbs
      echo oLink.TargetPath = "C:Program FilesANSYS Incv211FrameworkinWin64 unwb2.exe" >> CreateShortcut.vbs
      echo oLink.Save >> CreateShortcut.vbs
      cscript CreateShortcut.vbs
      del CreateShortcut.vbs
      ping -n 20 127.0.0.1 > null
    • George Karnos
      Search for Sccm on here there are some posts..
      https://forum.ansys.com/discussion/comment/145694#Comment_145694
